touch osc layout for ipad w/o osculator
    4youreye
    by 4youreye » Sat Oct 16, 2010 11:01 am
    this is my first try of an osc layout for the ipad which is working directly with the osc module and you dont need to use osculator. it has feedback, which is really cool, but not working always
    it´s very basic, small and all on one page - sorry for that, ilan ;)
    but it gives you an understand how the keyword system is working
    most important thing at the moment is to know
    0 = selected layer
    -1 = all layer
    the rest can be explored with the script output of m8
    here is the download
    http://files.me.com/gery4ye/rc9gea
    have fun
    gery
    4youreye
  • mowgli_uk
    by mowgli_uk » Sat Oct 16, 2010 11:32 am
    I'm getting this mesage:
    "failed to open layout. File might be corrupted or unreadable"
    I was curious to see what you've done as I've been working on a similar thing although I ended up using both OSC and MIDI through osculator as I found the native OSC capabilities somewhat limited on their own.
    by ilan » Sat Oct 16, 2010 6:11 pm
    Np Gery. I'll check it out. Thanks!
    by ilan » Sun Oct 17, 2010 12:47 pm
    I have the same problem. File corrupted.
    4youreye
    by 4youreye » Tue Oct 19, 2010 10:09 pm
    sorry,
    i pasted the new link above and tested it. its working now.
  • luiscript
    Another cute touchOSC layout for Modul8
    by luiscript » Mon Oct 25, 2010 7:46 pm
    I posted a free template for Modul8 and Ableton live in my blog:
    http://luiscript.com/2010/10/ipad-touch ... eton-live/
    Enjoy
  • blackwatch
    LUISCRIPT
    by blackwatch » Mon Oct 25, 2010 9:17 pm
    Gery & luiscript, your templates are fantastisch
    “The combination of hard work and smart work is efficient work”
  • hungry
    non XML version of this layout?
    by hungry » Mon Nov 29, 2010 12:18 am
    the new version of OSC Editor doesn't support XML layouts. do you have an updated version of your layout?
    thanks!
  • JazzT
    My template for Ipad to control modul8
    by JazzT » Thu Jan 27, 2011 12:57 am
    Hi, this is my first post here I just want to share with all you guys my TocuhOSC template for ipad to control modul8. I´ve got the good job of Gery and went one step more. I did two more pages with almost all controls and the Fx´s too. Hope you like and enjoy with it and please feel free to make all changes and give me your feedback and bugs about it.
    Wait for your comments.
    the file is here:
    http://files.me.com/jazztmusic/8qsd5z
    Regards
    JazzT
    nesral
    by nesral » Thu Jan 27, 2011 4:01 pm
    hello JazzT, touchOSC say : "Failed to open layaout. File might be corrupted or unreadable."
  • JazzT
    by JazzT » Thu Jan 27, 2011 7:36 pm
    I made the template with the last version of TouchOSC editor. Tri it with the last one (v.1.4.2)and will work for sure.
    JazzT
    nesral
    by nesral » Wed Feb 02, 2011 12:51 pm
    it works, Thanks ! :wink:
  • Przm
    by Przm » Sat Feb 26, 2011 5:45 pm
    Hey. The touchOSC template is fantastic! Thanks for the work there guys. Really appreciated.
    I'm a newbie, so I may have missed a step here, but once we've got the template in touchOSC, do we then need to manually assign add each control a unique ID in OSCulator and then manually assign it to the Modul8 control via MidiMap?
    Seems like a hassle seeing as the Template knows what everything is.. but like I say. I may be missing something here.
  • Przm
    by Przm » Sat Feb 26, 2011 5:53 pm
    OK. I just managed to get the OSC module hooked up.. so the Midi route isn't the issue any more. Everything linked up with nil manual assigning... bloody brilliant.
    I'd still be curious if there is a Midi map for the touchOSC template floating around. But for now its looking good.
  • Tango & Cie - Michel
    by Tango & Cie - Michel » Mon Apr 04, 2011 5:44 pm
    JazzT, Przm, if you have that Osculator layout mapped to MIDI, could you communicate it? I'm getting really nervous not succeeding doing that...
    I fear the OSC module is not for now so stable as Osculator... when you can get it work... javascript:emoticon(':roll:')
    Michel
    Tango & Cie
    www.tango-cie.com
