UPDATE v1.4
Now handles filter inputs.
it's in the online library
http://collectedconsciousness.wordpress ... nd-router/
it does indeed,By 'Filter' I mean audio frequency filter.
Meaning that you can apply the Low, Mid and High outputs of the 'Audio Analysis' function in M8.
To achieve this simply select one of the 'Full - Low - Mid - High' buttons in the frequency range section of the Sound Router module.
This module does not affect the FF or CC visual filters. If you wish to affect those filters with the sound input, I did make an edit of the Filters module which has an audio input.
It can be found in the online library titled: '(at) Filter (layer) v1.6'
However, the above module does not have any control over the Low, Mid, High values, and just takes the overall sound input level for the animation of the filters.
Hope this clears things up.
If you use the Sound Analysis set-up you can separate the left/right for the different ranges lo/mid/hi. You could even set the Hi to a low range and the Low to a high range if you wish:So, this module is great. Do you know if there is any way to have a layer or effect react only to one stereo channel, right or left? This would be an immense help for me, but I imagine also for others. I'm projecting onto a live band with 3D mapping. I'm looking to isolate bass drum hits from high frequencies, and the current frequency settings are tough to get a clear simultaneous isolation with.
