Locked 6 posts Page 1 of 1
The Midi does not work with Modul8 on my computer...
  • garageRoot
    by garageRoot » Thu Jul 29, 2004 7:07 pm
    In Modul8 2.5.x if you have connected your Midi device AFTER you launched Modul8 you will need to access 'Mapping > Rescan Midi devices' from application menu.
    In Modul8 2.6 scanning of Midi devices is automatic. When you connect your Midi device Modul8 will detect it and you will be able to map Midi commands immediately using 'Mapping > Edit Midi Map.'
  • fruitmedia
    Modul8 and Wii Remote?!
    by fruitmedia » Tue Nov 11, 2008 5:30 pm
    Hallo
    I tried to connect my Wii Remote controler with modul8. But in the Midi Map the Wii Midi commands are not identified.
    I tried to control a appelton live with the wii and everything runs, because I can allocate the cc1-cc127 commands.
    Is it possible to define the cc instructions manual in Modul8?
    best regards
    Martin
    by sigmasix » Tue Nov 11, 2008 5:52 pm
    what software do you use to convert wii signal to midi?
  • fruitmedia
    by fruitmedia » Tue Nov 11, 2008 9:44 pm
    Hey
    I use the OSCulator. In the meantime I managed that that modul 8 sent singals to the Osculator, but I need the reserverse effect.
    For the OSC signal I have a modul called OSC:)
    best regards
    by sigmasix » Fri Nov 14, 2008 3:51 am
    Did you install DarwiinRemote? you need it to send osc signal to osculator....
  • weirdqradio
    Ihave a novation
    by weirdqradio » Tue Feb 10, 2009 2:43 pm
    Ihave a Nvation usb midi keybard but cannot use it as a midi controller for the program what should i do
