timeline trigger?
  • filley
    timeline trigger?
    by filley » Thu Nov 04, 2010 1:04 am
    hi,,
    i'm searching for a possibility to trigger a clip by setting que points at various points in my timeline.
    until now i used the knobs next to the forward/back button in the main window with the potis of my midicontroller, but it's not as exact as i want it. i tried a lot of modules in the public libary, but these ones are just able to trigger with the clips in my mediaset.....
    can you help me?
    cheers,,
    fifi
  • mowgli_uk
    Re: timeline trigger?
    by mowgli_uk » Fri Nov 05, 2010 7:06 pm
    fifi
    What do you mean by this? You want to trigger clips not in your media set??
    Regarding the rest there's plenty of modules that do what you want - scratch one, media chopper etc
    deepvisual
    by deepvisual » Fri Nov 05, 2010 7:44 pm
    I think he wants to set accurate in/out points in clips like chapter markers
    best way to do that is an external editor - just cut it into lots of small clips.
  • filley
    by filley » Fri Nov 05, 2010 9:23 pm
    yes,, deepvisual is right.
    in the normal way, i can change the in and out point of my clip, but often that's not enough, when i want to 'play' with it.
    and it's to laborious, to have 5 layers with the same clip, but with another excerpt each.
  • mowgli_uk
    by mowgli_uk » Mon Nov 08, 2010 12:52 pm
    As I said there are several modules that do just that.
    Media chopper has fixed trigger points but movie scratch (layer) has 3 customisable trigger points.
  • filley
    by filley » Wed Nov 10, 2010 3:22 pm
    oh... yeah. mowgli.. thats exact what i need. thanks a lot! :D
