Installation with MoveBox HD and NEC Projektor MT1060
  • videsad
    by videsad » Sat Nov 20, 2010 12:34 pm
    Hello.
    I would like to make an installation. Here i use a HD-Movebox to play the Content. Player is a Beamer. (NEC MT 1060)
    Now i want that i set a timer to start and end the Installation. The switch is not a problem, because the projektor with automatic power sitches themselves.
    Turn Off that is there more of a problem. How can i turn off off time controlled the projektor without the lamp choke.
    please help me.
    Greets videsad
    by vanakaru » Sat Nov 20, 2010 5:47 pm
    I would program Arduino to do switch off in two steps. But you probably need some kind of physician switching scheme with it.
    Or leave it on stand-by.
  • videsad
    by videsad » Sat Nov 20, 2010 9:17 pm
    Do you have any other suggestions?
    by vanakaru » Sat Nov 20, 2010 9:42 pm
    videsad wrote:Do you have any other suggestions?
    Yes.
    But what have you thought yourself so far?
  • videsad
    by videsad » Sun Nov 21, 2010 12:10 am
    I found out that my projector switches off itself. When I use the media player shuts down it takes 5 minutes to the projectors which are concerned.
    The approach has the hardware for me too complicated.
    thanks for the tips
