greater accuracy
    deepvisual
    greater accuracy
    by deepvisual » Fri Dec 03, 2010 8:49 pm
    I'd love to be able to have greater accuracy over a number of features in M8
    I find the steps in everything from rotation to scale far too big.
    it would be great to have a universal adjuster that could nudge any selected item by a fraction of the usual amount.
    gmint
    Re: greater accuracy
    by gmint » Fri Dec 03, 2010 9:57 pm
    deepvisual wrote:I'd love to be able to have greater accuracy over a number of features in M8
    +1. Even with the multiplier slider (for lack of a better name) I find that it's difficult to make fine adjustments to the size of an image
    DJ G Mint
    by vanakaru » Fri Dec 03, 2010 10:26 pm
    Agreed! I find the best to use my finger rolling on MBP trackpad, but there are some jumps still. There is a module for tweaking position where you can type the numbers and arrow left-right by 1. So maybe a module would be possible.
    gmint
    by gmint » Fri Dec 03, 2010 10:28 pm
    vanakaru wrote:Agreed! I find the best to use my finger rolling on MBP trackpad, but there are some jumps still. There is a module for tweaking position where you can type the numbers and arrow left-right by 1. So maybe a module would be possible.
    What's that module called if you would?
    DJ G Mint
  • cycloptic
    by cycloptic » Fri Dec 10, 2010 3:10 am
    holding down the ALT key while using the arrows gives you 1/10th increments for all knobs and sliders
    deepvisual
    by deepvisual » Fri Dec 10, 2010 8:35 am
    cycloptic wrote:holding down the ALT key while using the arrows gives you 1/10th increments for all knobs and sliders
    yeah but its still one tenth of too much and it doesnt work on all knobs - rotate for example
    one hundreth would be much better
    by vanakaru » Fri Dec 10, 2010 9:48 am
    Layers position setter
