SWF doesn't play
  • imwinkel
    SWF doesn't play
    by imwinkel » Fri Jan 14, 2011 3:31 am
    SWFs used to play normally on Modul8 until today.
    I had this problem in the past. Official support could not help. Decided to do fresh install of Snow Leopard. Problem fixed. Now have same problem again.
    No errors, no messages, SWFs import fine in M8 library, play fine in Safari. Any ideas? Any help highly appreciated. I need to perform tomorrow.
    Info from Modul8
    Modul8 2.6.1 build 1105
    QuickTime 7.6.6 (1756)
    Adobe Flash 10.1.102.64 (10.1.102.64)
    Hardware Overview:
    Model Name: MacBook Pro
    Model Identifier: MacBookPro6,1
    Processor Name: Intel Core i7
    Processor Speed: 2.66 GHz
    Number Of Processors: 1
    Total Number Of Cores: 2
    L2 Cache (per core): 256 KB
    L3 Cache: 4 MB
    Memory: 4 GB
    Processor Interconnect Speed: 4.8 GT/s
    Boot ROM Version: MBP61.0057.B0C
    SMC Version (system): 1.57f16
    Serial Number (system): C02CJ0W8DD6Y
    Hardware UUID: 29742013-4F24-53DA-AB0F-B487AB0179BC
    Sudden Motion Sensor:
    State: Enabled
    by ilan » Fri Jan 14, 2011 1:41 pm
    Please try us at support again.
    I must re-iterate that as SWF is no longer supported by QuickTime, maintaining support for it is incredibly difficult and time consuming. I cannot recommend enough sticking with QuickTime formatted clips.
    tdog
    by tdog » Fri Jan 14, 2011 3:55 pm
    swf's play fine for me.....
    little plugin called 'perian' adds swf functionality back into quicktime.
    http://www.perian.org/
    tdog.
    by ilan » Fri Jan 14, 2011 4:23 pm
    True dat. Still, its not a solid solution. I still stand by my recommendation.
    tdog
    by tdog » Fri Jan 14, 2011 8:21 pm
    ilan wrote:True dat. Still, its not a solid solution. I still stand by my recommendation.
    i totally agree with your recommendation; but.... if you've already got some swf files, perian is easier than remaking them, and it's stable enough.
    tdog
Users browsing this forum: No registered users and 65 guests
