Stupid code newbie question.
    lotech
    by lotech » Sun Jan 16, 2011 5:15 am
    I'm attempting to merge a couple of modules to save on screen space. My understanding of coding modules is basic but so far I've managed to get everything working except I get an error on opening modul8, and by the looks of things it only needs a simple fix.
    So I've inserted this into PeriodicalEvent(elapsed):
    Code: Select all
    # crossfader control if run : if sec > 0 : pos = modul8.getValue ('ctrl_master_crossfader_slider',0) inc = (elapsed / sec) * dir pos += inc if pos > 1 : pos = 1; run = 0 elif pos < 0 : pos = 0 ; run = 0 elif dir == 1 : pos = 1 ; run = 0 else : pos = 0 ; run = 0 modul8.setValue ('ctrl_master_crossfader_slider',pos,0)
    And then when I open Modul8 I get:
    "NameError: name 'run' is not defined"
    So some pointers on how do I best define a name for the above code.
    Thanks.
  • anomad
    by anomad » Sun Jan 16, 2011 8:19 pm
    . if you've defined the variable 'run' in Init() add the line
    global run
    . at the beginning of PeriodicalEvent
    -james
    (a nomad. )
    lotech
    by lotech » Sun Jan 16, 2011 10:33 pm
    Thanks, I tried that and still am a bit stuck/confused. I've uploaded it here if someone wants to have a look.
    No Download (as we fixed it).
    I imagine its a 10 second fix.
  • anomad
    by anomad » Mon Jan 17, 2011 12:54 am
    . i didn't see run defined in Init()
    . i added it under last_time = 0.0
    run = 0
    . save, reload - two syntax errors
    . reload again, no errors! :)
    -james
    (a nomad. )
    lotech
    by lotech » Mon Jan 17, 2011 3:18 am
    Wicked thanks - I got another error about sec not being defined - so I did the same with sec = 0 in the init().
    I'll stick the final module in the online library.
    Thanks again.
