(LT) Clip Control 0.9 / (LT) Set layer to
    lotech
    by lotech » Thu Jan 20, 2011 2:44 am
    I've just put this on the online library. I haven't had a good chance to test it but wanted on another computer so thought I'd share it as is.
    Features
    - Thumbnail with filename, codec, duration & current FPS.
    - Scratch-able play head with
    - Set In/Out Points w/ Clear. Displays (in secs in/out positions).
    - Play/Pause/Rewind
    - Clip Speed Quick Keys / Speed Dial
    - Loop Mode Switches
    - Random Mode (needs work - too fast right now)
    - Set/Reset Layer button which turns normalize on, scales to 100%, speed to 100%. Also centres clip in X,Y,Z. and turns all Pixel FX to off - although sets Blur to BOX and amount to 0 (but still off).
    - Audio based playhead control - audio volume adjusts speed & audio adjusts playhead location.
    0.7 Fixes - playback FPS is acurate, filename & time is displayed in progress bar. In/Out time display.
    0.8 Fixes - Implemented Garagecubes Movie Time (layer) module. Audio playhead control and random is now tweakable. Added 'play once' loop button. Added speed rotary dial.
    0.9 Fixes - Made the module smaller so that (LT) Quick FX fits to the right of the module.
    BUGS
    There are some bugs, none seem to affect stability in anyway but I want to fix - if you have some knowledge to share please do.
    - The Module doesn't like there being no layers on the screen. Has somethign to do with how the thumbnail is drawn.
    - Some settings aren't always remembered when you switch away from a layer and back again. Nothing actually changes but some settings display old information until changed via the module.
    Also I've uploaded
    (LT) Set layer to..
    This again is just a one button setup of clips. Great for loading and setting it the way I want it (and hopefully you).
    Features
    - Turns on Normalize, scales to 100%, speed to 100%.
    - Centres clip in X,Y,Z.
    - Turns all Pixel FX to off - although sets Blur to BOX and amount to 0 (but still off).
    Please have a play and get back with feedback/bugs.
    lotech
    by lotech » Wed Apr 13, 2011 3:53 am
    I've just updated this with proper reset/auto fix button. If people want to give it a try and give some feedback that'd be just super.
    lotech
    by lotech » Fri Apr 15, 2011 10:18 am
    Spent more time on this module (along with all my other ones) - just uploaded v0.8.
    Lots of improvements.
    lotech
    by lotech » Thu May 05, 2011 2:29 am
    I just realised that I had a newer version than the online library - 0.9 is now there. It's smaller so if you use both (LT) Live Monitor & (LT) Quick FX it will all fit nicely around Modul8. See http://blog.lotech.co.nz/2011/05/messing-with-modul8/ for more info.
  • Lupin
    by Lupin » Thu May 05, 2011 9:16 am
    Thanks, you are working hard
    nice module
  • lamepantallas
    by lamepantallas » Fri May 06, 2011 7:48 am
    Hey Lotech! I just had to get online right now to say WOW! great module(s) > clip control & live monitor!!
    I was just preparing my show for tomorrow night and hadnt had time to check out the clip control with calm! Great features, great integration! Definitely using it tomorrow!
    Cheers from Honduras!! Yes Honduras, way down under ;)
    Saludos!
    gabbo
  • momoix
    by momoix » Wed Jul 13, 2011 10:23 am
    Hy,
    i`m new to modul8 and i i`m looking for a modul that shows displays me the duration of the clip in a layer in a form of a counter indicating how long the clip is gioing to play.
    it seems you modul is doing exactly that.
    where can i download it?
    best michael
  • mowgli_uk
    by mowgli_uk » Wed Aug 10, 2011 5:30 pm
    the answer to your question is on the FIRST sentence of the FIRST line of the FIRST post of this thread.........
