Will video clips WITHOUT an Alpha channel react to music?
  • soundman
    by soundman » Sun Feb 13, 2011 1:44 pm
    Can I make my video clip react to music (bounce/color organ/audio fft analysis) if my video clip DOES NOT have an Alpha channel?
    deepvisual
    by deepvisual » Sun Feb 13, 2011 4:01 pm
    yes, you'll just see the edges
  • soundman
    by soundman » Sun Feb 13, 2011 5:04 pm
    Edges of what? Will it make the image look bad? How much of the "edges" will be shown?
    by vanakaru » Sun Feb 13, 2011 6:52 pm
    soundman wrote:Edges of what? Will it make the image look bad? How much of the "edges" will be shown?
    When your video gets smaller or moves around the you start seeing the edge of your frame. So instead of image reacting to the sound as you would see if you use image on transparent background, you get the whole picture from edge to edge.
    But why do you ask and not try to see yourself? And make sure you understand what alpha channel means.
Users browsing this forum: Bing [Bot] and 8 guests
