Looking for a way/module/filter to create "trail"
  • comatory
    by comatory » Sun Feb 13, 2011 3:12 pm
    I am aware of the "Trace" global filter. It works allright, although from what I have gathered you need to have luma key on.
    I am actually looking for a way to apply this sort of effect to a certain layer, best solution would be via Filter module.
    I used to use "Alpha trail" effect in Resolume but I have been unable to find it. From some info I found online I am a bit confused. Are there freeframe effects that are just Win or Mac only? Also, are those effects stable with M8?
    I guess my ultimate question is:
    Is there a way to download just the alpha trail effect and put it in plug-in folder?
    Thanks.
