some of modules dont work~
  • mosu
    by mosu » Wed Mar 09, 2011 2:29 am
    Hi there,
    I'm just a beginner of modul8, and today I found something strange:
    I downloaded OSC(global) and Shake(global) modules from online Library and they didn't work anything, no pannel was pooping out, nothing happen. Still the same after restarting modul8.app .
    Then I opened them in Editor I found all the content, script, layout, even the author info are all empty.
    Back to OSX Finder those .m8m file size are only 4kb...I dont think this is the right size for a script.
    Is there anyone know what's going wrong?
    VjKg
    by VjKg » Wed Mar 09, 2011 2:37 am
    Try removing Modules and downloading again. Then do a google search on the difference between pooping and poping.
  • mosu
    by mosu » Wed Mar 09, 2011 2:45 am
    thx for reply.
    I've tried to deleted them from Finder and also tried to overwrite them directly from online Library, still the same.
    what can I do ?
    and sorry for the mistake I made. :shock:
  • mosu
    by mosu » Wed Mar 09, 2011 5:44 am
    http://www.garagecube.com/forum/viewtopic.php?t=5263
    I found the same issue, still no solution yet...
    beginner from Taiwan.
  • mosu
    by mosu » Wed Mar 09, 2011 10:46 pm
    After reading some other topics, there are some wrong with Online Library .
    Can anyone help me sending a OSC(global).m8m via email or tell my where can I get the modules in other way?
    Thanks !
  • mosu
    Problem solved!
    by mosu » Thu Mar 10, 2011 5:41 am
    Finally I found the solution from other Forum.
    some one in Taiwan who also had this problem and was told to change Mac OS language to English then reboot, it fixed.
    ghostofelvis100
    I concur!
    by ghostofelvis100 » Thu Apr 07, 2011 12:27 am
    Had a similar situation myself with a module I was uploading. Never did get to the bottom of it. Ilan at garagecube did some testing. I think we gave up in the end as when he uploaded the mod it worked. Was very weird and frustrating though.
    My machine has always been set to English.
