What Hardware to input 2cameras+ on macbookpro, canbedone?!
  • yo steve
    by yo steve » Thu Mar 17, 2011 3:04 am
    i need to insert 2 cameras (or 3) into modul8 running on a macbookpro, what is the interfase or equipment i need to be able to see and use them?
    i'm doing great with one camara via firewire but now need more.
    i know processing would be hard, also, recommendations for a good small camera that i can place up on truss.
    the addl camara will be far away so i need to convert the signal,
    etc. many questions.....
    i need help as i'm spec'ing a job, am learning as i go, would appreciate any support!
    Steve
    lotech
    by lotech » Thu Mar 17, 2011 3:10 am
    Check this thread
    http://www.garagecube.com/forum/viewtopic.php?t=3951
    You best way would be a DV/Firewire input along with a USB input. You can only ever do one Firewire input at a time, and once your use more than 1 USB capture device you will need to lower the incoming resolution to fix both feeds down a USB2 bus.
    by sigmasix » Thu Mar 17, 2011 3:11 pm
    you can do 4 firewire at the same time, but you cannot do more than 1 DV cam at the same time. Depending on your setting, 4 firewire inputs can be quite heavy to manage for your computer
  • yo steve
    Thank you guys!
    by yo steve » Wed Mar 23, 2011 8:03 pm
    great info, been reading up, getting clearer for me.
    question: is there a way to convert signal from mixer out to Firewire800 input on the Mac to M8? i would think this is faster, less latency.
    thanks again!
    Steve
    lotech
    by lotech » Fri Mar 25, 2011 10:22 pm
    The best/simplest/cheapest way would be a DC60+ and a video glide license. $US45 and being that it uses USB you can leave your Firewire bus for an external harddrive.
