How do i start/ stop all media in one group?
  • djarth
    by djarth » Sun Mar 27, 2011 6:09 am
    Hi all,
    Been playing around with Modul8 for few weeks, need some help.
    I cant figure out how to start/ stop all media in one group at the same time.
    Read the manual several times, don't seem to find it.
    I have a set of QT movies in layers which i have to start all at the same time.
    Can someone point me in the right direction
    Much appreciated!
    Thanks
    Justin
    lotech
    by lotech » Mon Mar 28, 2011 3:28 am
    Easiest way would be a module. And set a button to do something like this:
    modul8.setValue('ctctrl_layer_movie_speedFactor', 0, 0)
    That only sets speed to zero for each active layer but getting it to do all 5/10 layers should be easy enough.
    by ilan » Mon Mar 28, 2011 3:21 pm
    You can also use the DC-Play-STOP module and simply bind 1 key to all play buttons and 1 key to all the stop buttons.
    Depending on how soon you need it I can cook up a 2 button module that will do exactly what you need. Let me know.
  • djarth
    by djarth » Tue Mar 29, 2011 4:13 pm
    Thank you all for the tips!
    Sorry but how do you "bind" the buttons to one key?
    I'm currently using a play all/ stop module with reset, but to play, it involves clicking on the speed and to stop, its to click on 0 speed.
    Its a bit tricky for the play part as i might not click on the correct speed
    Thanks again for all your help
    by ilan » Tue Mar 29, 2011 5:31 pm
    Brain fry... it's not possible.
    To play and stop all layers all at once download the module I just uploaded 'DC-PLAY-STOP-ALL-LAYERS'
  • djarth
    by djarth » Wed Mar 30, 2011 3:59 am
    Thank you very much!!!!
    markvideo
    by markvideo » Sun May 08, 2011 12:58 pm
    But how you do play more than one layer with one mouse click / midi command etc.?
    by vanakaru » Mon May 09, 2011 2:01 am
    try module Activate Layer
    markvideo
    by markvideo » Tue May 10, 2011 4:44 pm
    can't find"activate layer" ?
    14:26
    found something called 'Layer Selector'. i'll try that
    14:37
    starts multiple layers but i'll need to be playing other layers at the same time or at overlapping times, so won't reallyt work for me.
    ++ 'layer selector' activates a layer but can't start the clip if it's in 'play once' mode.
