Mutliple MIDI-as-USB Issue
  • ffollowffocus
    by ffollowffocus » Mon Mar 28, 2011 11:02 pm
    Hi there! I'm just starting to get my feet wet with Modul8, but I'm running into one giant hurdle that's keeping me from advancing properly.
    I'm a semi-terrible electronic composer, which means I have a number of cheap MIDI-as-USB devices in my possession that I'm setting up within Modul8's MIDI configuration mode. The problem comes when I try hooking up more than one device at once - for whatever reason, all of my separate devices are being read as part of the same device (my keyboard's pitch bend is read as 1/1, while one of my turntable's dials are also 1/1, etc.). I am running the devices through a USB hub, but OS X's MIDI configuration is reading them independently, so I'm uncertain if that's the problem.
    I've read through the forums and the documentation extensively, but I haven't found anything that seems to mention this issue. Can anyone offer some guidance as to what I'm doing wrong?
    Thanks for your help!
  • anomad
    by anomad » Mon Mar 28, 2011 11:31 pm
    . change the MIDI channel that each device is sending from.
    . if that's not possible, look into MidiPipe to re-route the MIDI from one device to another channel
    . modul8 does not differentiate (in the mode your using) between CC messages and MIDI note messages
    -james
    (a nomad. )
  • ffollowffocus
    by ffollowffocus » Tue Mar 29, 2011 12:37 am
    Nomad, thanks for your help! I'll try MidiPipe shortly to see if that resolves the issue.
    You mention that Modul8 doesn't differentiate in the mode that I'm in. Is there a mode that I could set it to that would address the problem (assuming that MidiPipe doesn't fix it)?
    Thanks again!
  • anomad
    by anomad » Tue Mar 29, 2011 2:57 am
    . no, modul8 does not differentiate between the two. usually, it's not a big deal. you can set most MIDI controllers to send different channels - it all depends on the piece. i have an Ohm36 which sends CC changes and notes down the same channel, but has software where I can set the CC and note channel/values. so i made all the sliders/knobs transmit on channel 2 and all button on channel 3. most modern ones have software that you can use to change what value the key/dial/slider/button/etc. send.
    . i'm pretty sure you can use MidiPipe to create a 'Message Converter' and select 'control change #' for in and 'note on' for out.
    . MidiPipe - http://web.mac.com/nicowald/SubtleSoft/MidiPipe.html
    . another useful tool is MidiMonitor - http://www.snoize.com/MIDIMonitor/ for seeing exactly which messages are being sent.
    -james
    (a nomad. )
