Scenes module and AutorRewind module
  • Lupin
    by Lupin » Sat Apr 02, 2011 10:44 pm
    Hi guys, you'll find Two new modules
    (lpn) AutoRewind (Layer) : this module rewinds a media when a layer is activated the module is contextual and presets are saved with the project
    the other one is (lpn) Scenes (Master) : it's a Scene manager. It records layersets and crossfader modes with a custom caption thanks to a snapshot button in the edit mode.
    In the trigger scene mode, hit buttons to recall a saved scene. Presets are saved with the project. It's very handy when you want to use either the A/B crossfade mode or when you want to build a comp up to 10 layers.
    enjoy
    lotech
    by lotech » Sun Apr 03, 2011 2:14 am
    Auto rewind is great, something that should be built in the main gui. Thanks.
    VjKg
    by VjKg » Sun Apr 03, 2011 8:38 pm
    Both new Modules look very promising. I have to spend some time with them and see what trouble I can get into.
    by ilan » Sun Apr 03, 2011 9:14 pm
    Ok...
    Now how about a module that saves the time/position of a movie in a layer within a layer set so that when you go to another layer set an then go back to it the movie starts from the point it was before the layer set changed.
    by vanakaru » Sun Apr 03, 2011 11:50 pm
    Ok...
    I assume you are working on this vigorously.
  • Lupin
    by Lupin » Mon Apr 04, 2011 3:50 am
    Ok...
    it's already sketched on my modules to build list and… i built it tonight it. it's a first draw based on a speed record/stop/recall.
    the module is named: (lpn) AutoResume (layer)
    of course do not use the autorewind and autoresume module in the same time for the same layer.
