if modul8 read png seq. ?
  • timothy_boreale
    by timothy_boreale » Wed Apr 06, 2011 11:15 pm
    [size=18]i have many 1-2 sec clips which make from AE, than i am looking for the best code which render with alpha channel.
    photo-jepg is not allow me output as rgba .
    i am thinking if i can use png seq. to load into modul8 , or there is a way to play with png seq . ?
    thanx \
    VjKg
    by VjKg » Wed Apr 06, 2011 11:34 pm
    you can load as a movie folder. Just import the entire folder with the .png's.
    by sigmasix » Wed Apr 06, 2011 11:53 pm
    in AE, you can use Animation or PNG codec to produce a .mov file with alpha channel
  • timothy_boreale
    by timothy_boreale » Thu Apr 07, 2011 6:50 pm
    thanx for fasr reply .,
    to vjKg ,
    that you mean i can drug my folder into modul8 , and it will import as a video not image ?
    to sigmasix
    thanx, i never know that ,thanx so much
    by vanakaru » Fri Apr 08, 2011 12:02 am
    No you need to write a .mov choosing PNG + alpha(Millions of Colors+) out of what ever app you are using to make the image sequence. AE, Quicktime Pro and so on. Then you can play this movie in M8 with transparent parts.
    by sigmasix » Fri Apr 08, 2011 12:41 am
    but you can also just drag your folder of image and it will play as a movie
