MIDI mapping problems
  • jm302
    by jm302 » Fri Sep 23, 2005 3:55 am
    Greetings,
    From the thread http://www.garagecube.com/forum/viewtopic.php?t=500
    when using "edit midi map",
    for example, it says for a moment "1/36" ( the button I pressed ) but then immediately some other false message goes in, such as "1/0" or "1/99".
    Here's what I've noticed: certain MIDI controllers, when plugged in via USB, will cause the problem mentioned above (when mapping to a module). When plugged into a firewire interface via MIDI cable, the above problem goes away. USB seems to be the culprit, but I couldn't tell you why.
    Cheers,
    Justin
    http://www.302acid.com
  • Akira
    by Akira » Mon Sep 26, 2005 2:28 am
    I suppose this being a fault of the MIDI controller/interafce used, since I have no problems either with my Edirol PCR30 or my Edirol UM-1SX.
    by boris » Mon Sep 26, 2005 8:21 pm
    We are not able to reproduce this problem.
    Can you use the "printDirectEvent" to show what exactly your controler send ?
  • refresh
    by refresh » Wed Oct 19, 2005 4:27 pm
    I had this issue as well using a KORG microKontrol. In my case it was caused by my midi controller sending a midi clock signal @ 1/0.. It was solved by turning the midi clock off (on my unit just turning the tempo knob all the way down till it says "clock off").
    This clock message was overriding the other signals coming from the controller..
  • plasticpool
    by plasticpool » Sat Oct 22, 2005 9:04 am
    oh, thankyouthankyouthankyou for having a microKontrol and encountering the same problem as me! :D turning off the clock message worked.
    VJFranzK
    by VJFranzK » Wed Oct 26, 2005 10:32 am
    sorry, have not had time to really read the forum in a while.. Will investigate, and bring the direct event data...
    Hmmm... turning off the clock signals?
    This might solve the problem with the Korg Electribe also? Will try.
    (Actually, though - Is there a way that Modul8 could recieve the clock tempo?)
    yves@garagecube
    by yves@garagecube » Wed Oct 26, 2005 4:26 pm
    Well, you should be able to receive midi clock messages in the DirectEvent script of the module system. However it is up to you to do something with them, because Modul8 does not use midi clock information at all.
    VJ-A2D
    by VJ-A2D » Wed Oct 26, 2005 4:39 pm
    The why not make a global midi clock for the next m8 ;)
    It is a bit anoying having to set the BPM in each modul...
    Plus2 Collectiv
    yves@garagecube
    by yves@garagecube » Wed Oct 26, 2005 7:29 pm
    You are right. Centralizing the BPM/clock is something we plan to do for quiet some time. It won't be integrated for the V2.5 (too many other things to do), but definitively for the V3.0.
    Yves.
  • Akira
    by Akira » Fri Oct 28, 2005 5:18 pm
    Hmm I think I mentioned it before.. The Electribes don't send your standard fare of MIDI, they send some mixed shit of sorts. There is a MidiOx patch to mak the Electribes perfect controllers, but that means you will need a PC, and you will be adding latency to the equation.
    I don't know why Korg did that with the electribes :evil:
    VJFranzK
    by VJFranzK » Sat Nov 05, 2005 10:14 am
    Anything but that! ;)
    VJFranzK
    what is this rawEvent?
    by VJFranzK » Wed Nov 09, 2005 12:09 pm
    getting ready for a show
    okay. I have the oxygen 8 attached and am printing direct events for midi
    control messages show up normally when I move the knobs,e tc.
    but also an endless stream of something like this:
    param1 0 rawEvent 254 channel 0 param 2 0
    about 1 per second. (even if Im doing nothing) what does that message mean?
    when I try to set any knobs of a module, they are reset to 1/0
    it's impossible to control any module.
    though it works fine to control the "main interface" of m8?
    this oxygen 8 is destined for the scrap heap soon.
    trying to decide on which new control...
    yves@garagecube
    Re: what is this rawEvent?
    by yves@garagecube » Wed Nov 09, 2005 5:30 pm
    Hmmm... 254 in hexa is 0xF4
    It is a sys realtime message for "Active Sensing (Sys Realtime)". You should be able to disable it?!
    VJFranzK
    by VJFranzK » Thu Nov 10, 2005 1:10 am
    1. You mean disable it on the Oxygen 8 itself, or somewhere else?
    2. So that message isn't caused by a broken control, but some system function
    yves@garagecube
    by yves@garagecube » Thu Nov 10, 2005 1:08 pm
    Something is sending to Modul8 the 254 message periodically. This is a midi message called ""Active Sensing (Sys Realtime)" (from I saw in the midi references). I may be wrong, but I guess it is the Oxygen 8 which sends this message... So maybe there is a way to disable that.
    PS: A small correction from by previous post: 254 of course is not 0xf4, but 0xfe. (It changes nothing, because 0xFE is the command for "Active Sensing (Sys Realtime)")
