MIDI mapping
  • KjellV
    MIDI mapping
    by KjellV » Mon Apr 18, 2011 10:31 pm
    Hi there guys,
    I was wondering if there's a way to make two midi buttons act like the up and down buttons on the keyboard, just to jump to the layer you want to edit.
  • anomad
    by anomad » Tue Apr 19, 2011 12:54 am
    . yes... you'd want to create a custom module that would have:
    . a button for up
    . a button for down
    . then just determine the currently active layer - and move to the next/prev available layer.
    . creating a module is easier than you think and the :modules forum is really helpful if you come across any problems
    -james
    (a nomad. )
  • KjellV
    by KjellV » Tue Apr 19, 2011 8:45 am
    I'll try it, thanks for the reply!
    I'll most likely be back on the forum soon for some help on the module :p
  • KjellV
    by KjellV » Tue Apr 19, 2011 12:00 pm
    I've found a user-made module today that uses rotary knobs to browse both the layers and the media bank, love it!
  • KjellV
    by KjellV » Wed Apr 20, 2011 5:05 pm
    I've edited one like that to my needs and now it's perfect! thanks for the help!
  • martyw79
    by martyw79 » Mon Apr 25, 2011 6:32 pm
    what module are you referring too?
  • KjellV
    by KjellV » Mon Apr 25, 2011 8:43 pm
    one of the versions of live monitor, but now i've made my own module that works even better, need info?
  • martyw79
    by martyw79 » Mon May 02, 2011 9:03 am
    I found the modified version of the Live monitor module, thanks!
