Change LayerPosition
  • KjellV
    by KjellV » Fri Apr 22, 2011 1:34 am
    Can anyone get me started on the script code to make a rotary knob control the position of the active layer within the layerstack?
  • anomad
    by anomad » Fri Apr 22, 2011 4:29 am
    . i'm not sure that you can do that.
    . i seem to recall you can get a number that based on the layer in layer set (ie, the 10th layer at the bottom is 0, the next one up is 1, the top layer is 9 for layer set 1. when changing to layer set 2 at the bottom, the number is 10, etc.)
    . but i don't know if you directly assign one layer to another.
    . what sort of effect are you trying to achieve?
    -james
    (a nomad. )
    lotech
    by lotech » Fri Apr 22, 2011 4:43 am
    I think (vv) live monitor v2 does what you're asking the LAY dial on it moves the selected layer up or down.
  • KjellV
    by KjellV » Fri Apr 22, 2011 8:23 am
    What the live monitor does is change the layer focus, but that's not what I meant.
    The final goal for my mudule is that there is a rotary knob that controls which layer is focused (I already have that), but when a certain button is pressed the rotary knob acts as if you were dragging the layer with the mouse. What I especially need to know (I think) is how the command "ctrl_layerStack_positionChange" works.
    by sigmasix » Fri Apr 22, 2011 2:11 pm
    hi,
    it was quite easy, the tough part was to understand how the needed keywords work… So I made a module for you: (s6) Knob2LayerPosition
    You can get it in the public library.
    You can all check the code to see how to use the layerstack keywords.
    The best way to understand how to use a badly documented keyword is to use the PrintDirectEvent tool and check what happens when using the control you want to work with.
  • KjellV
    by KjellV » Fri Apr 22, 2011 2:35 pm
    thanks a lot man! really appreciate it!
  • anomad
    by anomad » Mon Apr 25, 2011 8:58 pm
    . oooh! great tip! :D
    -james
    (a nomad. )
