codecs issue :(
  • Be
    codecs issue :(
    by Be » Fri Apr 29, 2011 10:50 pm
    Hi, had any one of you problem with basic codecs?
    Suddenly modul stopped recognizig videos like h264, apple pro res, photo jpeg, tiff.
    the same videos works fine with modul on other two machines.
    Thanks
    expect unexpected
    VjKg
    by VjKg » Sat Apr 30, 2011 5:28 am
    Do they play in Quicktime?
  • Be
    by Be » Sat Apr 30, 2011 3:18 pm
    Yes they do...
    Modul reads some files for example apple prores from last gig, but dosn't read the same codec i just exported from motion or cinema. Really wierd
    expect unexpected
    deepvisual
    by deepvisual » Sat Apr 30, 2011 9:50 pm
    check the frame rate
  • Be
    by Be » Sat Apr 30, 2011 10:53 pm
    thanks, i've checked its 25 or 30 but there is hope, after system reinstalation I've just exported mov /apple prores/ from motion and it reads now. Looks like the previous files had some errors or something, still does not read h264 25fps, but the other modul on the other machine does :/
    expect unexpected
