Modifying existing modules to add save feature
  • d3v1an7
    by d3v1an7 » Wed May 04, 2011 3:40 am
    Hey all,
    I'm using (vs) Media Sequencer 1.0, in which the author has saving on the to do list. It hasn't been updated since 2008, so I'm doubting it'll happen any time soon.
    With no knowledge of module coding, how easy would it be for me to add the ability to save the module presets to the project save file?
    Is there some kind of documentation on implementing features like this?
    Thanks heaps.
    lotech
    by lotech » Wed May 04, 2011 4:01 am
    It would be easy for some of the more advanced module makers as there is support for saving states but a little beyond me.
    To be honest you should look into (at) Layer Sequencer 10x16 v2.0 as its a more complete version of the same idea. It may include saving but I'm not too sure as I've only just seen the use of a bpm sync'd layer changer (going for a piss/drink/dance).
  • d3v1an7
    by d3v1an7 » Wed May 04, 2011 4:24 am
    Thanks lotech - I actually need to run both :)
    I'm already running the layer sequencer for BPM sync, but I would like some of the layers themselves to switch media over time as well.
    I've come across setDefaults / getDefaults in the manual and will give it a shot. Looks like that'll actually save into the module, but I'm not too bothered about that.
    Hopefully it saves the different module states for each layer - we'll see.
  • d3v1an7
    by d3v1an7 » Wed May 04, 2011 4:50 am
    Hm, well I've tried that, along with setting 'Auto-Serialize' for each of the visual elements.
    It saves the last instance of the module, but not for each layer.
    I've had a peek at other modules and it looks like it'll be a bit more complex unfortunately.
  • Lupin
    by Lupin » Wed May 04, 2011 9:34 am
    use the InDict /outDict blocks
    the outDIct block is the place where you save your data with your project when you close it
    if you want to save a variable like
    Code: Select all
    test="text string"
    write:
    Code: Select all
    outDict['test'] = 'text string'
    or to save the variable
    Code: Select all
    outDict['test'] = test
    to recall this saved variable when you open your project, go to the inDict block and ask the script if the data was saved with the project, if so, then recall it and apply it to the test varable.
    write:
    Code: Select all
    if 'test' in inDict: test=inDict['test']
    you can save numbers, strings, lists, dictionaries with the outDict dictionary.
    lotech
    by lotech » Wed May 04, 2011 9:42 am
    Wow that straight forward explanation just answered all my questions about saving things in modules. Thanks Lupin!
  • Lupin
    by Lupin » Wed May 04, 2011 10:18 am
    you are welcome i added something to the script.
    but i guess you already got the idea of how it works
  • d3v1an7
    by d3v1an7 » Wed May 04, 2011 1:37 pm
    Hey Lupin, thanks for the clear explanation :)
    I understand that concept, but I'm not sure how to save arrays of data for each specific layer.
    I'll keep at it, but I'll post parts of the original code - the parts I'm pretty sure need changing.
    if anyone has any ideas, I'd really appreciate it!
    All of this code is in init()
    The save function is called whenever the user edits the sequence
    Code: Select all
    def saveSequence(): module.setDefaults ( {'seq1': sequence} )
    And here is the load...
    Code: Select all
    sequence=[] prefs = module.getDefaults()
    I'm pretty sure this is the setup...
    Code: Select all
    if prefs == {}: # sequence =[1,2,3,4,5,6,7,8,9,2,10,11,12] module.setDefaults ( {'seq1': [1,2,3,4,5,6,7,8,9,2,10,11,12]} ) else: sequence = prefs['seq1'] print sequence
  • Lupin
    by Lupin » Wed May 04, 2011 2:32 pm
    Hi d3v1an7
    your strategy is the worst when it comes to save datas for each layer.
    you'd rather use a contextual layer module and use the inDict / outDict blocs to save it.
    this dictionaries save datas from each layer as long as you checked the contextual layer checkbox within your module.
    otherwise it becomes a real nightmare if you wanna deal with arrays and dictionaries to save each layer's properties.
  • d3v1an7
    by d3v1an7 » Thu May 05, 2011 4:40 am
    Cool - makes sense.
    I'm having trouble getting the script to output saved variables though.
    I've done the following:
    Serialize(outDict)
    Code: Select all
    Deserialize(inDict)
    Code: Select all
    Init()
    Code: Select all
    print (test)
    This gives me a runtime error
    Code: Select all
    NameError: name 'test' is not defined
    Any ideas?
  • Lupin
    by Lupin » Thu May 05, 2011 9:09 am
    you did not declare the test variable previously.
    you can't create a gloabal variable within a script aside of the init bloc.
    by the way i'm the author of the media sequencer ;) visionsonore was my former company
    i did not updated the media sequencer module coz it's really time consuming and since it's impossible to publish,update or delete modules from the public library if the module was created on another computer - that's was my case unfortunatly - i couldn't even update it today.
    Wait for the online module manual, you'll find the answers to start to modify and build your own modules. it will be released soon.
  • d3v1an7
    by d3v1an7 » Thu May 05, 2011 9:27 am
    Haha rookie error, my bad - I've clearly got a long way to go :)
    Proper documentation would be amazing - I'm used to looking up functions and having in depth explanations and examples when working with jQuery/Wordpress etc - spoilt really.
    I feel quite blind starting out in Modul8, everything is trial and error at the moment.
    Thanks for your amazing work on the module in the past, it's exactly what I need. If I can manage to get it to save, I will let you know :D
  • d3v1an7
    by d3v1an7 » Fri May 06, 2011 2:01 am
    Sorry to keep bumping, but I'm going around in circles at the moment.
    Is there some way for me to declare a variable without assigning it a value?
    Atm, I'm doing the following
    Init()
    Code: Select all
    testVar = 123 print testVar
    MessageEvent(msg,param)
    Code: Select all
    (On button press...)testVar = 456
    Serialize(outDict)
    Code: Select all
    outDict['STORE_TEST'] = testVar
    Deserialize(inDict)
    Code: Select all
    if 'STORE_TEST' in inDict: testVar= inDict['STORE_TEST']
    Finish()
    Code: Select all
    print testVar
    When resetting the script, the val 123 is returned for both finish and start prints.
    I know why it returns 123 on init (it has only just been declared), but can't figure out why it returns the same value on finish, as it should have changed on button press.
    When does the variable get stored? When the button is pressed? Or when the document is saved?
    I feel like I'm missing something fundamental here :p
    Any help is appreciated :)
  • Lupin
    by Lupin » Fri May 06, 2011 10:48 am
    the variable is saved in the the outDict when you close your project
    the inDict is called when you open a project
