Engaging saved MIDI in M8 docs.
  • skyvat
    by skyvat » Wed Sep 28, 2005 2:27 pm
    I have 1 patch wher MIDI won't respond until the MIDI map mode is engaged. Once I turn it on, and then immediately off, the MIDI works.
    Anyway to fix that? I'm worried about accidentally changing an assigment as enter and leave the mode.
    Thanks
    Dan
    yves@garagecube
    Re: Engaging saved MIDI in M8 docs.
    by yves@garagecube » Wed Sep 28, 2005 5:57 pm
    skyvat wrote:I have 1 patch wher MIDI won't respond until the MIDI map mode is engaged. Once I turn it on, and then immediately off, the MIDI works.
    Thanks
    Dan
    Hmmm... never saw that before... What is your configuration ?
  • skyvat
    by skyvat » Thu Sep 29, 2005 7:04 am
    I'm running a 12" g4 powerbook with a Behringer BCF 2000 plugged direcly into the USB port. Other M8 docs with MIDI seem to load fine - but this one file loads with this problem every time.
    Sould I email it to you?
    Oh, another thing I noticed today. I made a module and used a midi trigger to activate a button in the module. Then I changed the value sent by that button (from ctrl movie speed .25 to .5). Then, when I triggered the module button through MIDI it still sent the old .25 value, but when I clicked the button directly in the screen interface, the new .5 value was sent. I fixed this by entering MIDI map mode and reassigning the MIDI note that triggers this button.
    The original problem still remains, though. Maybe that case will give you a clue?
    Thank you,
    Dan
    yves@garagecube
    by yves@garagecube » Thu Sep 29, 2005 6:30 pm
    skyvat wrote:Sould I email it to you?
    Yes, this would be helpful! Thank you.
