The Midi Thief wrote:Destroke, you sparked a little idea:
So then I thought what if you could make a QC audio visualizer that runs in iTunes and sends info to Modul8 via Syphon. I was a bit surprised that it works. I don't know what info you need but I have artist and song title showing in Modul8.
To answer your first question: yes it possible. Question is what ID3 data do you want and what do you need to do with it?
The Midi Thief wrote:QC Rehab should say in the instructions (readme file?). It goes in a special place in the library folder. Syphon Client QC.qtz gets loaded in to Modul8s media library. But these are just the corner stones to make the rest work.
