Locked 27 posts
What is this 'Spacial Scanner'?
  • naidustays
    Re: What is this 'Spacial Scanner'? "Could not capture witho
    by naidustays » Fri Dec 28, 2012 3:36 pm
    Hi I just recently got a mac book pro and a canon 60D. I downloaded the demo on my mac and clicked on spacial scanner. It immediately detected the canon but not the resolution. When I clicked on capture, it gave me a pop-up tha t said "Could not capture without an external display configured". What should I do? Since this cost me a lot.
    by ilan » Fri Dec 28, 2012 4:05 pm
    Is your computer connected to a projector?
  • emilesteginga
    by emilesteginga » Fri Apr 19, 2013 1:04 am
    I have also a 60D and since recently I cant use it anymore as says every time I connect the camera its says that Raw is still on and can't use the scanner. I think it is a bug. How can I fix this?
    is there a fix for it?
    by franz » Fri Apr 19, 2013 1:21 pm
    The Space Scanner DOES work with the Canon 5d Mark II - that's the camera we own and use for our installations at 1024architecture - . Please try to describe more precisely the issue you're having.
    Use a good USB cable with ferrite node at the end, not too long.
    When you plug your camera, does MadMapper display its name in the list of available devices in the Space Scanner module ?
    Does MadMapper display an alert ?
    Then, eventually, consider contact the support, they'll guide you through a procedure.
  • south888
    by south888 » Sat Apr 20, 2013 1:33 am
    my 60D doesnt work nether. the projector is running on full screen and which is connecting with mac book pro, camera image size is S, and Manual, Manual Focus.
    the camera name on the display in the list of available devices, but when i crick on the "capture", "could not capture without an external display configured" pop up appears.
    I think Madmapper doesnt recognise the projector because it screening just my computer display onto wall. supposed be its not same screen as the Special Scanner Tutorial on your website. (on the 4th image of the tutorial webpage)
    maybe 60D doewnt work with special scanner?
    by ilan » Sat Apr 20, 2013 10:41 am
    The 60D is a new model, so we may need to update something. We had the same problem with the new 5D models. We'll look into this asap.
    by franz » Mon Apr 22, 2013 4:32 pm
    note that it won't work if your external projector display is in Mirror Mode.
    (which sound obvious to me, but we never know)
    by sigmasix » Tue Apr 23, 2013 8:51 am
    maybe a canon sdk updater right into madmapper would avoid to update the whole madmapper every time there's a new model?
    by franz » Tue Apr 23, 2013 11:45 am
    the problem is that we're using the latest SDK already, and the 60D *should* work, as noted in the SDK release notes.
    We'll look into this issue ASAP.
    To those who have a 60D, can you contact the support directly and they run you through some tests in order to make it work (at least try)
    by franz » Tue Apr 23, 2013 12:37 pm
    @emilesteginga: do you have the preview working (inside the space Scanner module) with the 60D ?
  • emilesteginga
    by emilesteginga » Wed Jun 05, 2013 4:11 pm
    franz wrote:@emilesteginga: do you have the preview working (inside the space Scanner module) with the 60D ?
    Yes I had it working, but I found out how it was not working. It was because I had the Magic Lantern Software installed on my firmware, when I had set it back to the original firmware, it was working again. Thanks for responding though ;-) (and sorry for the late reaction)
  • thyeks
    by thyeks » Fri Sep 06, 2013 5:25 am
    Hello I just bought a Canon 70D with EDSDK 2.13 Version
    And It doesn't work, no preview, and the message is " Image quality should be set to jpeg only (not RAW or jpeg+RAW).
    Do you have some answers? How can I use it?
Locked 27 posts
