getting started with syphon
  • castlerox
    by castlerox » Sat May 28, 2011 10:47 pm
    I am very confused as to how to get things started...
    I will be buying the full version early next week, but have the demos and 2.6.2.
    I am really confused as to how syphon works. I have both apps open. I can't seem to find syphon...? Can someone link me the actual download page? All I see are the demo's.
    Once they are installed, how are you they used between modul8 and mapper? So far the software looks great and clean but I can't get the two linked.
    Help?
  • martyw79
    Hello
    by martyw79 » Sun May 29, 2011 8:19 am
    In Modul8 2.6.2 set the Output to Syphon.
    Once you've done this it'll appear in MadMapper under 'Syphon'.
    You don't need to download/install Syphon because it's build into the software.
  • lamepantallas
    by lamepantallas » Thu Jun 02, 2011 9:07 pm
    Hello, I have two Macs, a relatively new one and an old one. When using syphon, in which one would you recommend I use M8 and MM in order to have a smooth run or does it not affect it at all?
    esegabbo
    PopVersus
  • monsho
    by monsho » Thu Jun 02, 2011 11:07 pm
    you need to use both on the same Mac, the newer one I guess...
  • jaxamuse
    Re: getting started with syphon
    by jaxamuse » Wed Feb 01, 2012 8:18 pm
    "In Modul8 2.6.2 set the Output to Syphon.
    Once you've done this it'll appear in MadMapper under 'Syphon'. "
    I do not agree with the above statement.
    I'm outputting from Modul8 no problem, but there does not appear to be any "Syphon" input in Madmapper.
    It's frustrating, because everything I've read says that once you send the feed from Modul8, it will just magically appear in Madmapper, and this isn't my experience.
    Help, please,
    thanks!
    pele2010
    by pele2010 » Thu Feb 02, 2012 2:01 am
    HI , just wondering and asking:
    1. You did set the output in MD8 that is cmd ( and y)
    2. With a source selected you switch to MM
    3. In MM you have to select Modul8 syphon input . By default you see a checkerboard
    Under the Text "Syphon" you see Modul8 - Main View
    If you select this you will see the selected clip from MD8.
    I hope this helps .....
    here is the tutorial from the madmapper website
    http://www.madmapper.com/modul8-madmapper-tutorial/
    pele2010
    www.instagram.com/pele2010/
    #eachfilm01
    #pele2010
    www.eachfilm.de
