Assign bpm to footage
  • Jaysonaut
    by Jaysonaut » Fri Jun 03, 2011 7:38 pm
    Hey folks,
    is there any way to assign a bpm to your footage (like it`s possible with the kaptivator) with modul8 or another software?
    Thanks for any answers! Best regards - JJ[/url]
  • anomad
    by anomad » Sun Jun 05, 2011 2:54 am
    . i haven't found a way to directly embed that information, so i just put the bpm in the filename - then use a module to get/use that value.
    -james
    (a nomad. )
  • Jaysonaut
    Re: Assign bpm to footage
    by Jaysonaut » Wed Oct 19, 2011 7:55 am
    Thanks for your reply. I found a simple way: cut my footage into pieces of 15/30/... frames (at a framerate of 30 fps). So it`s easy to fit to the musik. Not what i wanted but looks even good with breakdance :) cheers.
