Animated colour gradient
  • versicolor
    by versicolor » Fri Jun 10, 2011 9:01 pm
    I'm about to try and make a module that animates colour gradients like this:
    http://robinsonheath.co.uk/video/gradient.mp4
    Can anybody give me any pointers?
    The clip was made in Apple Motion where the effect is called 'gradient colorize'. I've animated it with an offset from 0 - 359 degrees and it runs through the gradient 4 times throughout the clip. Repeat method is mirror and Map channel is Luminance.
    - N
  • Lupin
    by Lupin » Sat Jun 11, 2011 8:42 am
    animate the NI core filter Linear Gradient or Radial Gradient .
    you already can animate them though the Filter module.
