Control points do not appear in preview output
  • lumnz
    by lumnz » Sat Jun 11, 2011 6:59 pm
    I am having a strange problem with the controls when using quads.
    The control points only appear in the input side of the workspace and are limited to proportional scale only. the control points for the quad do not appear at all in the preview output and I have no control over skew or perspective making the process very useless.
    The mesh warping feature seems not to work at all.
    i can move points around and it seems to create a mask with the shape of the modified mesh but does not warp the output image at all.
    very frustrating
    is there a feature i need to enable to access these fundamental tools?
    by sigmasix » Sat Jun 11, 2011 7:06 pm
    what's your configuration? what is your graphic card?
  • lumnz
    by lumnz » Sun Jun 12, 2011 9:23 am
    Thank you for your reply sigmasix
    Config:
    2.16 Ghz Intel macbook Pro
    2GB Ram
    Chipset Model: ATY,RadeonX1600
    Type: GPU
    Bus: PCIe
    PCIe Lane Width: x16
    VRAM (Total): 256 MB
    Mac OS X 10.6.2
    Build 10C540
    Modul8 2.6.2
    Madmapper 1.0 (980)
    by ilan » Sun Jun 12, 2011 10:14 am
    MadMapper has a problem with Radeon cards. That is why you are experiencing this problem. David will work on a fix this coming week.
  • sundog
    by sundog » Tue Jun 14, 2011 2:36 pm
    same card and same problems here too...
    thought i was going crazy trying to follow the mesh warp tutorial.
    glad this forum is up now, otherwise i wouldn't have known
    cheers, sundog
  • zampano
    by zampano » Tue Jun 14, 2011 7:04 pm
    hello,
    i have the same problem...
    cordialy
    Mac os 10.6.7 / Build 10J869
    Modul 8.6.2
    Mad mapper 1
    Config:
    2GB Ram
    Type: GPU
    Bus: PCIe
  • MAURO
    by MAURO » Mon Jun 20, 2011 1:05 pm
    same here with ATY,RadeonX1600(MBP).
    As workaround point your curser were the control-points normaly should appear or are expected. Funtionalities for edting on the output window is working but the control-points are not rendered.
    by ilan » Mon Jun 20, 2011 2:11 pm
    The problem is with Radeon cards. We are aware of it and a fix is on the way.
    david
    by david » Tue Jun 21, 2011 5:28 pm
    Hi all,
    we identified the problem with the Radeon X1000 (1600/1900/*) cards, it is a bug in the OSX OpenGL driver.
    we found a workaround for MadMapper. Please contact us at support [at] garagecube.com to get the patched version.
    We plan to release it next week but we want a confirmation that it works on your configs.
    Regards
  • lumnz
    by lumnz » Thu Jun 23, 2011 7:03 pm
    many thanks for the quick fix. I hope this helped.
