Madmapper Fullscreen
  • Callen Tham
    by Callen Tham » Fri Jun 17, 2011 1:02 pm
    hi, i just purchased madmapper and testing it out with a projector. fullscreen output on projector is working well but i wonder how can i hide the quad's 'Surface indicator' ie "Surface 1" and the white borders that appear in the projrction. hope to solve this problem as i have a gig this weekend. thanks.
    by ilan » Fri Jun 17, 2011 2:05 pm
    Output | Show info
  • Callen Tham
    by Callen Tham » Sun Jun 19, 2011 9:01 am
    Hi Guys, I installed MM into 2 models of MBP.
    13” MBP (having problem with MM output)
    Config:
    2..8 Ghz Intel Core i5 macbook Pro
    4GB Ram
    Chipset Model: Intel HD Graphics 3000
    Type: GPU
    Bus: Built In
    VRAM (Total): 384 MB
    Mac OS X 10.6.7
    Modul8 2.6.2
    Madmapper 1.0 (980)
    15” MBP (working Fine with MM)
    Config:
    2..8 Ghz Intel core 2 Duo macbook Pro
    4GB Ram
    Chipset Model: NVIDIA GeForce 9400M
    Type: GPU
    Bus: PCI
    VRAM (Total): 256 MB
    Mac OS X 10.6.3
    Build 10C540
    Modul8 2.6.2
    Madmapper 1.0 (980)
    Hope its just a bug...
  • Callen Tham
    by Callen Tham » Sun Jun 19, 2011 9:04 am
    I have tried un-clicking 'Show info" but projection went blackout.
    by ilan » Mon Jun 20, 2011 1:13 pm
    Is 'Object Isolation' de-selected? It is a button located on the upper right side of the MadMapper interface.
  • Callen Tham
    by Callen Tham » Tue Jun 21, 2011 6:35 am
    yes, 'object isolation' is switched off.
  • Callen Tham
    by Callen Tham » Wed Jun 22, 2011 10:13 am
    Do you have an answer for my problem. I really need to know because i have to use it this weekend. Thanks.
    by sigmasix » Wed Jun 22, 2011 1:46 pm
    hum, do you have any media in the input window?! in the settings tab, the opacity is not set to zero right? when you say blackout, is it written blackout in red in the preview output?
  • Callen Tham
    by Callen Tham » Wed Jun 22, 2011 5:39 pm
    media is in the input window with quad. Opacity 100%.
    What i mean "blackout" is no image on my "fullscreen output" projection when "Output | show info" is switched off. same problem when i switch to "Output | Desktop".[/img]
    by boris » Sun Jul 24, 2011 7:03 pm
    Is your problem resoved ?
    Please note : for a faster support please use our email support.
    Boris.
