Questions regading Python, Nodebox
  • bareimage
    by bareimage » Thu Jun 23, 2011 10:55 pm
    Hello, I have a weird question. Is there a way to import Nodebox scripts into the Modules and when is there going to be a possibility of update to later python implementation?
    by The Midi Thief » Sat Jun 25, 2011 5:39 pm
    Do you want to use a Nodebox library? You can't change which version of Python Modul8 uses by yourself. You have to adapt the code to an earlier version of Python if necessary. Which Nodebox library do you want to use? Iv'e adapted Nodebox Color library to work with Modul8 so I know it's possible but it all depends on what the code does. If it's heavily depending on a newer Python version, then you have a lot of work to do.
