is there a search function for missing media files?
  • R-e-R
    by R-e-R » Fri Jun 24, 2011 7:31 pm
    Hi there,
    i recently installed a 2nd HDD in my MBP for my media library and then moved my media files to the new drive....now when i load an older M8 project it loads but says "some media files are missing".
    is there a way to point to a folder and locate missing media files?
    best regards, thanks for any advice.
    by vanakaru » Fri Jun 24, 2011 9:45 pm
    No as far as I know. Just pain in the whatever.
    You need to open your project in text editor where you can see what media files were used and where these were located in first place. You may be able to search and relocate then.
    by ilan » Fri Jun 24, 2011 9:53 pm
    Or, simply move all of your project files to where the media is located. As long as your Modul8 project file is at the same folder level as your media Modul8 will find it. Any media a directory above it will not be seen. Since your project files are small there is no reason to keep them separate from your media files.
