Modul8 Crash after 10min
  • videsad
    by videsad » Fri Jun 24, 2011 10:04 pm
    Hello
    Last weekend I worked with Modul8. When I have a video input via firewire camera Panna Sonic, and a Sony PS3 WebCam connected to the laptop. Additionally, I have imported photos. I had the problem that after about 10 minutes the program crashes unexpectedly.
    I restarted the laptop. I had the problem again for 2 times.
    I work with a MacBook Pro 2.5GHz Intel Core 2 Duo with 2 GB Ram
    Modul8 V 2.6.2
    My questions:
    - What can I do, however
    - Which modules are necessary to enable a smooth operation
    - If I install my camera, it happens that my MacBook freezes
    I am asking for immediate help
    Greets videsad
    lotech
    by lotech » Fri Jun 24, 2011 10:27 pm
    Disable any modules first off. Make sure Modul8 is working well with just the basic app and then with your cams.
    by ilan » Sun Jun 26, 2011 12:00 pm
    @videsad please send your message to support [at] garagecube [dot] com.
    Please provide the following along with it:
    1 - your Modul8 serial number.
    2 - Modul8 console logs (Console application is in your in Utilities folder)
    Best,
    Ilan
