Using image as mask and multi-inputs for quads
  • technomorph
    by technomorph » Fri Jul 01, 2011 1:53 pm
    So after seeing DeepVisuals post about doing a multi output from Modul8 to get more than one available input via Syphon I see I have to wrap my head differently on how to get media into Mad Mapper.
    I really wish could use some multi-syphoning technic from each layer.
    or use the Advanced Output somehow. As the multi output method doesn't really give you a way to "Previsualize" your work in MD8
    As far as using media (such as Photos taken of actual projection objects) to use for masks, I guess I'll have to go the same route and use up another layer in MD8 and just add them as regular quads?
    This is where I can see using VDMX as a way advanced method as I have way more fexibility with inputs/outputs and general routing and create seperate WYSIWYG preview window and another output that will send to MADMAPPER for use. I could also create multiple Syphon outputs too.
