Source And Setting " window seems to be " crashed
  • SirAlex
    by SirAlex » Sun Jul 03, 2011 10:27 pm
    Hello All,
    I'v been working in M8 with 1080p SDI video capture via BlackMagic DeckLink Studio.
    Suddenly I lost access to the "Compression type" in M8, Im stuck in Uncompressed 10-bit 4:2:2
    The M 8" Source And Setting " window seems to be " crashed " .
    I'v tried to reinstall M8 but it stays the same.
    Is there any files a must remove from the system to full reset M8?
    Best regard
    Alex
    by sigmasix » Sun Jul 03, 2011 11:54 pm
    the settings window is related to quicktime… did you update your OS or Quicktime?
    lotech
    by lotech » Mon Jul 04, 2011 12:15 am
    It could be the blackmagic drivers. They quite infamous for releasing drivers that add/fix stuff but also break other stuff.
    Also (someone correct me if I'm wrong) but changing the compression on a video in is unnecessary as it's more of a pass through and you should get better performance with it set on uncompressed anyway.
  • SirAlex
    by SirAlex » Mon Jul 04, 2011 1:15 am
    I dint update Qt but updated BM drivers, but only after the problem, trying to resolve and dint work.
    What else can i do?
    What is the difference from "uncompressed" to "none" when selecting a codec?
  • SirAlex
    Re: Source And Setting " window seems to be " crashed
    by SirAlex » Sun Nov 20, 2011 1:09 pm
    Reinstalled OSX, now its ok.
    Thanks
  • randomBboy
    by randomBboy » Wed Jan 22, 2014 3:11 am
    This just happened to me, is there any other fix besides reinstalling the operating system?
