button reacts on both up and down
  • Donleavy
    by Donleavy » Fri Oct 07, 2005 11:38 pm
    Hey there
    I am trying to make a module with a button for the next media and a button for the previous media in the mediasets. The module is pretty simple, but the buttons keep reacting on both down and up. I have set the down value of the button to 1 and the up value to 0, but it doesn't seem to help. The only way I can get it to work is to set the button to "toggle". But it isn't really a toggle button...
    What am I doing wrong ?
    I upload the module to the public library for you to inspect: Previous+Next
    yves@garagecube
    by yves@garagecube » Sat Oct 08, 2005 12:53 pm
    You should check the "param" dictionary sent with the message.
    Typically you receive a value in the param, 1.0 for down and 0.0 for up.
    For example
    Code: Select all
    if param['value']==1.0: print 'button is down' elif param['value']==0.0: print 'button is up'
    If you want to see the parameter that you receive simply print the param dictionary and check the result in the console:
    print param
    result for down is:
    {'NAME': 'Untitled', 'value': 1.0}
    result for up is:
    {'NAME': 'Untitled', 'value': 0.0}
    NAME is the name of your control.
    by sigmasix » Sun Oct 09, 2005 8:54 am
    ok, but what about if we want to deactive the up value (I have the same problem but it doesn't really change my module but that would be better ;))
    can we do something like that?
    Code: Select all
    if param['value']==0.0: param['value']==nil
    nil or something similar... I don't know :roll: :wink:
    thanks
    yves@garagecube
    by yves@garagecube » Sun Oct 09, 2005 12:22 pm
    Not sure what you mean by "deactiving" a value. If you are not interested by the up mouse event you can simply ignore it.
  • Donleavy
    by Donleavy » Sun Oct 09, 2005 2:12 pm
    Thanks for the answer.
    I simply put the "if param['value']==1.0:" into my script, and now it works. It looks like this:
    Code: Select all
    if msg == 'next' : if param['value']==1.0: val = modul8.getValue('ctrl_layer_media',0) newVal = val+1 modul8.setValue('ctrl_layer_media', newVal,0)
    /Donleavy
    by sigmasix » Sun Oct 09, 2005 10:43 pm
    :P I'm quite stupid :roll: I was thinking in the wrong way... :x :lol: Donleavy just opened my eyes :wink: thanks
