Mad Mapper Output to Syphon
  • technomorph
    by technomorph » Wed Jul 13, 2011 8:22 am
    Is there any reason why the Output from Mad Mapper can't be outputed to Syphon?
  • garageRoot
    by garageRoot » Tue Jul 26, 2011 12:06 pm
    It is being discussed for a future release.
    tdog
    Re: Mad Mapper Output to Syphon
    by tdog » Tue Jul 26, 2011 5:08 pm
    technomorph wrote:Is there any reason why the Output from Mad Mapper can't be outputed to Syphon?
    Please clarify,
    As I see it, MadMapper is the 'last' stage before projection - therefore syphon out is not a necessity?
    Would not inputing MadMapper into another app negate it's function?
    Not that I use MadMapper, just following the post with interest, trying to learn.
    Thanks,
    tdog.
    haye
    by haye » Tue Jul 26, 2011 8:33 pm
    Please clarify,
    Thanks,
    tdog.
    consider this:
    you might want to feed your final output back into your composition.
    for example you could create animated outlines of your shapes on-the-fly with oscillating edge detection filters.
    or you might like to record your final composition with syphon recorder.
    or http-stream it elsewhere if there was a program for that.
    i guess it would be a function which caters to creative signal routing..
    best,
    haye
    p.s.: i second that request!
    tdog
    by tdog » Wed Jul 27, 2011 12:18 am
    Ok, cool.....
    thanks,
    tdog
  • MacroMeez
    by MacroMeez » Tue Nov 22, 2011 9:33 am
    I would also like to see this feature to record the output to send ideas to collaborators or clients.
  • t.francis
    by t.francis » Wed Jun 06, 2012 12:27 am
    Well, a good reason would be to output on multiple displays without a matrox dual or tripleHead2go. We could output madMapper via syphon to Max or Quarz Composer and stretch the composition over wathever screen configuration... A MacPro with two ATI Radeon HD 5770 could then output on five displays (one being used for control).
    t.francis
    by sigmasix » Wed Jun 06, 2012 1:27 pm
    Syphon output exists in MadMapper. You just can't access it from madmapper to avoid unwanted behaviour.
    orion
    by orion » Tue Jul 03, 2012 12:32 pm
    yes, what sigmasix said. For example, open MAD_Doubler (which has a syphon output too btw) and you select any of apps with a syphon output. Here you can see I have several options, mad mapper being one of them:
    MAD_Doubler
    Screen shot 2012-07-03 at 5.20.54 AM.png (62.91 KiB) Viewed 28681 times
    I suppose if you wanted to input your MM output into say M8 then you'd have to use a qtz work around, sending Mad_Doubler to QTZ (syphon server) to Modul8. Not sure if the chain will be exactly what you want as i've dizzied myself...
    orion
    by orion » Tue Jul 03, 2012 1:36 pm
    hmmm....i guess if you did that then you'd have two madmapper outputs in one.
    Mad_Doubler 2
    Screen shot 2012-07-03 at 6.21.19 AM.png (172.31 KiB) Viewed 28681 times
    you could just route it like; MM to QTZ to M8 (without the MAD_Doubler) and run the M8 feed back into MM to create a little step effect i guess.
  • gabemott
    by gabemott » Mon Jul 09, 2012 12:15 pm
    Not exactly sure what this all means. What is the best way to record a madmapper session? With Syphon? How? The need for this is that while madmapper does seem the ideal live performance tool and it's quick, it can still be a vital part of rendering a pre-composed piece. So far it seems to me that instead of rendering everything in after effects (for example after exporting a map from mad mapper) there is a lot more flexibility and ease of timing things to music if I am able to record a live output of my madmapper flow. Thanks.
    by franz » Thu Jul 19, 2012 3:45 pm
    use syphon recorder (available free on syphon website) to record MM's output to video file
  • gabemott
    by gabemott » Sun Jul 22, 2012 5:43 am
    Great! Easy. Except...
    So just turning on Syphon recording automatically is ready to capture the output from Madmapper but my resolution is coming out wrong. The resolution of my projector is 1280x1024. When I syphon capture the video recorded is 1280x720.
    I restarted, checked the resolution output in madmapper (OUTPUT>FULLSCREEN (1280x1024). When I capture a snapshot, the snapshot is the correct resolution 1280x1024.
    Is there a way to force Syphon to capture the specified resolution?
    I'm also getting confused by the Stretch Output option. Unfortunately, our last rehearsal is wednesday so I don't have the actual projection stage model to test on until then. I tested last Thursday but wasn't aware of the Stretch Output option and everything went well but I don't know if I had stretch output on-- don't think so.
  • gabemott
    by gabemott » Sun Jul 22, 2012 5:45 am
    Also, I checked and am using the current version of Syphon. beta9
    by franz » Mon Jul 23, 2012 12:06 pm
    InSyphon Recorder Preferences, there are options to setup up your recording size etc...
