Wish List: multi output, precise tools
  • Lupin
    by Lupin » Thu Jul 28, 2011 1:38 pm
    •add multiple outputs
    •an advanced property window to tweak quad values more precisely
    •a quad/mesh snapping
    • add Right click mouse shortcuts and menu
    •add/edit keyboard shortcuts
    •add a color point reference for triangles.
    •change the outline color
    •add a light strobe/invert effect for output quad setup
    •improve the mask tool
    •let the choice in preferences to offset or not the input or outpuquad when duplicated
    •add Bezier deformation in addition to meshes
    • add a reference poitn tracker to setup quad/mesh poitn reference with a laser pen for instance a nd create dynamic and quicl video mapping
    man it would be crazy if we could track finger nails like a director who'd frame a picture before he shoots it.
    •add a preset window or workspace to enable/disable locka dn show/hide quads.
    •add MIDI trigger
    •load 3D object
    •add a Camera or multiple veiws for multiple output windows
    •unfold 3D objects to quads
    •add an online architecture data bank object library.
    •add a media grid loader
    •enable an input per quad or create a mad mapper plugin for modul8 or quartz composer.
    •add a duplicate window 'like in photoshop to see the zoomed windows and the big picture)
    •add a "make it random", "get mad" button to create a random number and quad transformation
    tdog
    Re: Wish List: multi output, precise tools
    by tdog » Mon Aug 15, 2011 3:29 pm
    Lupin wrote:•add multiple outputs
    •add MIDI trigger
    •load 3D object
    drink chilling module
    spliff rolling plugin
    tdog.
