modul8 controlled by DMX?
  • area71
    by area71 » Thu Aug 04, 2011 8:00 pm
    how can I control modul8 by DMX?
    I have the enttec pro an it is recognised. Now I want to use a MA GrandMA to control the layers and the clips. But how can I set it up? Is there a chart like the midi or key control?
    cheers,
    area71
  • Lupin
    by Lupin » Fri Aug 05, 2011 12:29 pm
    Use The DMX ci tire module from The online library to pair DMX
    Carlos.Leyva
    Re: modul8 controlled by DMX?
    by Carlos.Leyva » Thu Aug 11, 2011 6:33 pm
    area71 wrote:Hi,
    cheers,
    area71
    Yes, you can control with the module "dmx fixture", I control through a hog 3 and works the same way as catalyst of high end, you can do scenes, cues, anything!
  • area71
    by area71 » Fri Aug 12, 2011 2:07 am
    thanks for the reply.
    But I think there is something more wrong with the enttec and OSX:
    I can get it recognized on my old mbp with 10.5.8 with the pro utility, but not with modul8.
    On my mbp with 10.6. the enttec isn´t even found by the utility programm.
    Under windows it works fine. :-( I have updated the enttec to1.44
    So which OSX do you use? I read that there are some problems with 10.6. and the enttec?
    regards,
    area71
    Carlos.Leyva
    by Carlos.Leyva » Fri Aug 12, 2011 10:54 pm
    area71 wrote:Hi,
    regards,
    area71
    Hi, i have a Mac os x 10.6.7 on my macbook pro...
    - First you need Modul8 2.6 or later because this version support "dmx receive or send", then download enttec pro driver http://www.enttec.com/index.php?main_me ... =dmxusbpro
    - Once you have the driver installed. Connect enttec pro, check that the DMX signal
    - In the modul8 preferences under the DMX tab make sure you can see that the ENTTEC device is recognized and that modul8 is in "receive mode"
    - Download from the online library "dmx fixture" If all is well should be receiving signals from your console, you can control and program your scenes video-lighting
    This is really amazing because you can record light and video to the single cue, just that I love, enjoy!
    cheers!
