NOT WORKING export output
  • technomorph
    by technomorph » Fri Aug 05, 2011 3:02 am
    - on site
    - retweak images to match the actual stage
    - get it locked in go to EXPORT OUTPUT so that
    can now share this with the other VJs involved in the festival
    and discover that the the EXPORT OUTPUT function does not work
    by sigmasix » Fri Aug 05, 2011 11:26 am
    again, what is not working?!
    it's working pretty well on my computer
  • technomorph
    by technomorph » Fri Aug 19, 2011 1:25 pm
    the FILE->EXPORT OUTPUT function.
    I was onsite. Adjusted our "temp photo template" image to match the actual stage.
    Save.
    Arrive back at the studio and planned to export the new matched template so that
    i can start building material etc for it only to find out the Export function does not work.
    I tried all formats PNG, SVG, PDF
    and the only thing that showed up in the export file was:
    the Layer name and the framing of the layer/grid warp points.
    Using Madmapper 1.01
    Mac OSX 10.6.7
    MacBook Pro
    Model Identifier: MacBookPro8,3
    Processor Name: Intel Core i7
    Processor Speed: 2.2 GHz
    Number of Processors: 1
    Total Number of Cores: 4
    L2 Cache (per Core): 256 KB
    L3 Cache: 6 MB
    Memory: 8 GB
    AMD Radeon HD 6750M:
    Chipset Model: AMD Radeon HD 6750M
    Type: GPU
    Bus: PCIe
    PCIe Lane Width: x8
    VRAM (Total): 1024 MB
    Intel HD Graphics 3000:
    Chipset Model: Intel HD Graphics 3000
    Type: GPU
    Bus: Built-In
    VRAM (Total): 512 MB
    by franz » Sat Aug 20, 2011 12:48 pm
    The "SVG export function" exports the vectors, outlines, handles and names in vector format.
    If you want the bitmap as well, you can simply hit the "make snapshot " os shortcut. By default it is COMMAND SHIFT 3.
  • technomorph
    by technomorph » Sat Aug 20, 2011 11:52 pm
    i'm using the "EXPORT OUTPUT" function.
    selecting .png format
    by franz » Mon Aug 22, 2011 8:00 pm
    The EXPORT OUTPUT function works.
    If you select PNG (or SVG or PDF),
    it will export the wireframe outlines and naming of your surfaces.
    If you want the bitmap as well, just make a snapshot.
  • technomorph
    by technomorph » Thu Aug 25, 2011 9:01 pm
    I don't understand the point of that. That does not seem usedful.
    Screen Capturing a Bit Map is not going to give %100 pixel accuracy that is going to
    match exactly what is going to your projector
    by franz » Mon Aug 29, 2011 8:57 am
    The export function is needded if you want to work with Illustrator/after effects.
    The Mad_Line also has an export to SVG.
    Combining both allows for some crazy post prod effects.
    The OS screen cap is accurate for bitmaps.
  • lamepantallas
    by lamepantallas » Fri Sep 02, 2011 2:17 am
    Hi Franz, you just opened my eyes to whole new possibility I hadn´t realized, can you elaborate a little more on the export function for post-production please?
    gabbo
    by franz » Fri Sep 02, 2011 9:02 am
    well,
    you do your basic setup, put your quads, triangles, masks...
    eventually add some lines with the MAD_Line.
    Then you export everything.
    You'll have the outlines and naming of all your surfaces.
    Then you can use AE, or Illusttrator, to work flat as you used to.
    Just this time you know precisely where all the elements are located
    on the screen space.
    This way you can use MadMapper as an helper to provide
    a background for your post production works in AE.
  • lamepantallas
    by lamepantallas » Tue Sep 20, 2011 2:33 pm
    Gracias man! Thanks!
