Slide Show BMP - match bpm error
  • nearweb
    by nearweb » Fri Aug 05, 2011 12:09 pm
    everytime i press "match bpm" on Slide Show BMP module come out this error http://imageshack.us/photo/my-images/15 ... 20350.png/ and if i go to see the code i find this one http://imageshack.us/photo/my-images/15 ... 19184.png/
    any solutions??
    thank you
  • Lupin
    by Lupin » Fri Aug 05, 2011 12:35 pm
    The BPM_SPEED variable Is a shared dictionary variable, this means it can only be retrieved once a module has already written this variable in this shared dictionary. Are you sure that the BPM module is running? This is the one that sends this shared var
  • nearweb
    by nearweb » Fri Aug 05, 2011 2:00 pm
    Yes, i'm using (at) BPM (global) v3.0. I press ON and then TAP TAP till when i find the right time.
    Anything automatic like the left bar on (lt) QUICK FX v11??
  • camil
    Re: Slide Show BMP - match bpm error
    by camil » Mon Dec 12, 2011 12:08 am
    Just had the same problem and there is a simple fix:
    open BPM Global module in editor (now I'm using (at) BPM (global) v3.3 ) and add this line in PeriodicalEvent(elapsed):
    sharedDict['BPM_SPEED'] = speed
    Restart Modul8 and that's it.
    Screen Shot 2011-12-11 at 10.58.00 PM.png (248.17 KiB) Viewed 8146 times
  • proglime
    by proglime » Sun Mar 25, 2012 6:14 pm
    Thanks Dear Camil !
    slideshow works with bpm now.
    but i found a new problem:
    the SYNCH button in "(at) BPM (global) v3.3 )" seems no effect with the Slideshow BPM Module.
    when slideshow begin off beat, i cant re-sync it, even press "on/off" or re-activate the slideshow module, both no use.
    please go check it and help me.
    THANKS a LOT!
