matrox triplehead2go analog: help mac software needed
  • studioo
    by studioo » Sun Aug 14, 2011 7:50 pm
    hello together
    i just got a matrox triplehead2go analog, but the software is only for windows.
    so i`m not able to get a signal no left & right...
    would be nice if someone can help me asap cause i need it for tonight :-(
    thanks
    patrick
  • Lupin
    by Lupin » Sun Aug 14, 2011 8:41 pm
    you don't need any driver for the TH2GO analog, check you VGA or DVI connection and check the length of your video cables
  • studioo
    by studioo » Sun Aug 14, 2011 8:50 pm
    hello lupin
    thanks for your info!
    cool that i dont need a software
    i definitly get no signal on left and right.
    when i change the vga wires it`s still the same...
    there is no signal on left and right. do i have to do some settings?
    do you have any other idee?
    thanks a lot for your help.
  • Lupin
    by Lupin » Sun Aug 14, 2011 8:57 pm
    do you have a wide screen resolution output when you check for secondary monitors list?
  • studioo
    by studioo » Sun Aug 14, 2011 9:16 pm
    lupin
    what i try is:
    getting the center signal on the screens. that is fine.
    beside that, i would like to map the same modul8 input by madpapper on some cubs.
    my settings are:
    sypon output on 640px x 480px
    do handel that, i had the idee to use 2times the madmapper.
    1 for the screens (with modul8 input)
    1 for the cubes (same modul8 input)
    thanks
    deepvisual
    by deepvisual » Mon Aug 15, 2011 11:37 pm
    set your output in OSX sys prefs
    to something like 2400x600
    or some other 4:1 ratio
  • stephaniestep456
    Re: matrox triplehead2go analog: help mac software needed
    by stephaniestep456 » Tue Nov 26, 2013 10:02 am
    It would be wise if you can check the system requirements of matrox triplehead2go with the original equipment manufacturer and see whether if you have all the required features in your system. Such errors are mostly because of the configuration of system.
    Thanks
    snoringaidsnow.org
    by vanakaru » Tue Nov 26, 2013 3:38 pm
    Do you understand how this works. You send triple wide video 1920(3x640)x480 and th2go will split this into 3 monitors 640x480 each. If you send just 640x480 you get just the middle monitor showing the video bacause you do not have any content on the side monitors.
  • james442
    by james442 » Tue Feb 16, 2016 8:51 am
