audio and video in sync
  • visulize
    by visulize » Tue Aug 16, 2011 1:41 pm
    Hi all.
    so I'm playing back a video clip with audio attached..
    There seems to be quite a latency between the video and the audio track. ( basically lip syncing) is there any way to fix this??
    many thanks in advance.
    deepvisual
    by deepvisual » Tue Aug 16, 2011 1:51 pm
    what codec are you using?
  • visulize
    by visulize » Tue Aug 16, 2011 2:15 pm
    they are .mov files.
    deepvisual
    by deepvisual » Tue Aug 16, 2011 2:17 pm
    yes, but what codec are you using.
    it will have a big effect on how it performs
  • visulize
    by visulize » Tue Aug 16, 2011 2:18 pm
    not sure what your meaning.
  • visulize
    by visulize » Tue Aug 16, 2011 2:19 pm
    ah i see they are h264 arc codec
  • visulize
    by visulize » Tue Aug 16, 2011 2:23 pm
    oops h264 aac codec
    deepvisual
    by deepvisual » Tue Aug 16, 2011 6:35 pm
    try converting to apple intermediate codec or photojpeg.
    it might just work
  • visulize
    by visulize » Wed Aug 17, 2011 1:07 am
    thanks for that
    a bit better but still not quite there...
    many thanks for your knowledge...
