output export / bezier control / several inputs-outputs
  • pablo
    by pablo » Tue Aug 16, 2011 7:59 pm
    Hi, first of all congratulations for the software, it seems to be a great starting point.
    Just would like to give a couple of suggestions that may be worth considering for future releases:
    - exporting the final output to .mov file (photojpg) would be a key point for fixed installation users, once you have mapped and fixed the projector you can have a simpler setup/computer instead of having to run madmapper, easier for automatic start/shutdown.
    - Bezier vertex control on the warping grid. Being able to adjust the quantity of pixels one vertex moves with the arrows keys would be great, some hi-res mappings need really fine tuning.
    - Would be nice to be able to work with more than 1 input inside madmapper instead of having to use modul8.
    - also more than 1 output would be very useful and output edge blending: this is something I have found in higher end software and it is very useful for large building projections using several projectors. Most of the time you can do it with barco or christie projectors, but for some setups it has proven very useful to have software control.
    Hope it helps, keep up the good work
    pablo v
  • lamepantallas
    Re: output export / bezier control / several inputs-outputs
    by lamepantallas » Mon Oct 24, 2011 6:35 pm
    AGREE
  • fm2224
    by fm2224 » Tue May 20, 2014 6:23 pm
    YES to the exporting final output.
    I am currently running one such fixed, multi-year installation and would be the first in line to update if this feature were added.
    by franz » Wed May 21, 2014 3:29 pm
    you can export the final output using Syphon Recorder and activating syphon Output in the MM Preferences.
    you can bezier control the grid warp by enabling Bezier in the inspector, and right click a control point to change its tangents.
    you can nudge the grid points with the keyboard arrows
    you can have multiple outputs using MM 1.5.x ++
    edge blending is coming in 1.7
    multi input is in the tube, but for later
