Online Public Library not working
  • refresh
    by refresh » Wed Oct 19, 2005 4:20 pm
    I just bought m8 and wanted to check all the modules to see what ppl had made but i don't see anything at all in the online module library..
    any clues???
    thanks
    yves@garagecube
    Re: Online Public Library not working
    by yves@garagecube » Wed Oct 19, 2005 9:39 pm
    Well, Modul8 uses a standard web browser connexion to access the library. So as long as you can use Safari on your machine to browse the Internet you should be able to access the online library. Is there anything special with your Internet connexion (a proxy, ...) ?
  • refresh
    by refresh » Wed Oct 19, 2005 10:14 pm
    I'm using a bluetooth cellphone as a modem, so I guess that isn't technically standard.
    I'm not using a proxy, at least not one that I am aware of. There is a chance that my phones data comes through a proxy but I generally don't have any problems with my connection even using plug ins, streaming etc..
    not sure what is causing this, the little progress widget in the lower left spins a few times and then stops, nothing shows up in the list and there is no feedback at all as to what is going on.
    Is there any way i can see the modules via http??
    yves@garagecube
    by yves@garagecube » Wed Oct 19, 2005 10:36 pm
    This is weird. Did you try to use other browsers than Safari like FireFox or Explorer ? Did you install some drivers to access Internet through your cell phone ?
    Unfortunately, we don't have an html interface to the online library etc. We can send you the modules by email if you want.
  • refresh
    by refresh » Wed Oct 19, 2005 10:47 pm
    Yes I use firefox and explorer no problem also dreamweaver and trasnmit work fine..
    also i am a flash developer and do a lot of network related things with my flash files and don't have any problems.. strange..
    anyway i will try it again this weekend when i'm on the main island and can get on a friend's dsl connection.
    hopefully that'll work..
    thanks
