syncing audio/ sounds with finished projection visuals.
  • CAW
    by CAW » Sun Aug 28, 2011 11:42 pm
    I have a finished visual projection project finished and now wanting to sync sounds to the visuals. Is there any audio software which will allow me to display the finished visuals ( as in video playback) at the same time allowing me to create music / sounds ?
  • Basic
    by Basic » Mon Aug 29, 2011 12:59 am
    Could you not try something like Ableton? Would this work for your needs. I know you are able to sync them via midi.
  • CAW
    by CAW » Mon Aug 29, 2011 10:11 am
    ahh ok ill check it out , thanks
  • Basic
    by Basic » Tue Aug 30, 2011 3:15 am
    Are you looking for something in a live situtation or to render down for viewing?
  • CAW
    by CAW » Tue Aug 30, 2011 8:10 am
    Just looking for something for viewing at the moment. Just checked out Ableton Live and yes its exactly whats I'm looking for. I can slow down the visuals and create audio for certain parts. Thanks great help!
  • Lupin
    by Lupin » Tue Aug 30, 2011 1:56 pm
    I'm currently Using Qlab from figure 53 . this software is a timeline & event based software to manage audio+midi+image sync. though the programming paradigm is not user firendly it's a remarkable softawre to use along with M8 when you have to deal with Timeline and audio sync with audio spatialization. spatailization.
    [/url]
    deepvisual
    by deepvisual » Tue Aug 30, 2011 2:21 pm
    qlab can pipe into syphon too, with a little bit of quark magic.
  • Lupin
    by Lupin » Tue Aug 30, 2011 2:27 pm
    unfortunatly not,since syphon is not an official apple validated API, figure 53 will not embed this techno until apple officially approves it.
    but they are interested in syphon .
    deepvisual
    by deepvisual » Tue Aug 30, 2011 5:54 pm
    I have it working.
    someone made me a patch and it works fine.
  • Lupin
    by Lupin » Tue Aug 30, 2011 6:13 pm
    Could you also zend me the patch in pm please?
  • Basic
    by Basic » Wed Aug 31, 2011 2:23 am
    No worries CAW and nice link Lupin
  • CAW
    by CAW » Wed Aug 31, 2011 3:55 am
    Yeah ill check them all out thanks, cheers Lupin, Basic
Users browsing this forum: No registered users and 78 guests
