Two questions please
  • blckmttr
    by blckmttr » Mon Aug 29, 2011 4:50 pm
    Hello Everyone
    I am new to madmapper, and I plan to buy the soft for a project with a friend which happens by the end of september (i currently own modul8). Its a projection on a house and it's prepared in advance on after effect & I will use a macbook pro. I have setup the project on the MM demo and it works pretty well but I have two questions. What is the max resolution that I can use for my project (the first draft is currently in 1024x576) and is maddmaper handling sound or do I have to process the video sound with a different application?
    Thank you in advance.
    Greg
    by franz » Tue Aug 30, 2011 8:09 am
    The max res. should depend on your graphic card.
    If reading a movie , the max res. also depends on your CPU/HardDisk Speed/Chosen Codec.
    I've successfully handled 4096 * 2048 pixels resolution in MadMapper.
  • blckmttr
    by blckmttr » Tue Aug 30, 2011 10:22 am
    Hi Franz
    thanks for the the fast answer
    I'll run some tests
    G
  • lamepantallas
    by lamepantallas » Fri Sep 02, 2011 2:12 am
    I applied 3072 resolution and had no problems, even running a BIG quicktime file rendered from After Effects. Just remember to render your projects photo-jpeg at 85 quality.
    cheers,
    gabbo
  • blckmttr
    by blckmttr » Tue Sep 06, 2011 11:50 am
    I used H264 in 1920 and it seems to run smoothly
    But I am not sure to need a big res as the projection surface is not big
  • diez54
    by diez54 » Wed Sep 07, 2011 10:56 pm
    I've try with success 5760*1080, with modul8 and madmapper ( photojpeg codec) .
    On mac pro with ssd HD for files.
Users browsing this forum: Baidu [Spider] and 30 guests
