syncing several modul8-computers- howto ?
  • nbd
    by nbd » Sat Oct 22, 2005 1:11 pm
    we are trying to sync 3 macs running modul8 2.01 . How can this be done ?
    First thing we do is:
    a separate computer plays midi, all three macs are getting midi and play accordingly.
    so far, no problem.
    next thing we try:
    we use logic as midi-sequencer on one of the modul8-macs.
    problem: midi is feed through the system again and again, a midi feedback occurs.
    last, final:
    is there a way to steer modul8 via network(tcp/ip or udp), eg. osc or similar ? so all the midi-spookyness is not necessary ?
    that would be great !
    thank you !
    andreas
    by boris » Sat Oct 22, 2005 2:33 pm
    The version 2.5 come soon,
    With a module for sync several computers through ethernet (UDP).
  • noise
    by noise » Tue Oct 25, 2005 5:15 am
    Oh my god!!
    I swear i will flip if you tell me that we can make collaborative efforts with modul8 2.5!
    Please, give us more details!
  • noise
    by noise » Sun Oct 30, 2005 10:52 pm
    hellooo?
    by boris » Mon Oct 31, 2005 1:18 am
    It's a simple module in python to send or received or both the controls values of your(s) modul8 interface through upd.
    yves@garagecube
    by yves@garagecube » Tue Nov 01, 2005 1:46 pm
    Basically, this module allows you to create a network of machines with several Modul8 running as players and one Modul8 as the master controller. When you change something in the master, it sends the change to all its slaves. It allows you to do multiple projections using several Mac minis for example.
    Jesper Fryd
    by Jesper Fryd » Tue Nov 01, 2005 4:47 pm
    How's the latency?
    VJ-A2D
    by VJ-A2D » Tue Nov 01, 2005 7:07 pm
    why not use a splitter , if you are creating the same stuff all around!?
    Plus2 Collectiv
    Jesper Fryd
    by Jesper Fryd » Tue Nov 01, 2005 9:59 pm
    I guess that with the right modules, you would be able to manipulate the recieved signal on the other machines.
    For example if Master sends "scale", then Slave1 will multiply "scale" by 4 and Slave2 will divide it by 8.
    yves@garagecube
    by yves@garagecube » Tue Nov 01, 2005 10:09 pm
    You can choose what you want to sync. or not. Also you can work in very high res. comparing to a video splitter.
    Last edited by yves@garagecube on Tue Nov 01, 2005 10:14 pm, edited 1 time in total.
    yves@garagecube
    by yves@garagecube » Tue Nov 01, 2005 10:11 pm
    How's the latency?
    In UDP the latency is pretty low, as long as you're in a local network of course.
    Jesper Fryd
    by Jesper Fryd » Tue Nov 01, 2005 11:45 pm
    How's the latency?
    Pretty low...
    Is that low enough to have two clips trigger and play in 100% sync?
  • AZK
    by AZK » Fri Nov 11, 2005 2:25 am
    I've worked once with two laptops running Modul8 synced in midi.
    The set-up was really simple :
    - a BCR2000 for trigerring ;
    - 1 powerbook running Modul8 with a 1i/1o UNO midi interface ;
    - 1 powerbook running Modul8 with a 2i/4o M-Audio midi interface ;
    It worked perfectly.
    I guess that the new UDP communication brings a all new scape of application, just like the Medialon system using 1 master to control other players. Correct me if i'm wrong.
    AZK Team.
    Aïzenko :: Motion Graphics - Web Applications - Live & Interactive Exhibitions
    www.aizenko.com
  • vjrei
    by vjrei » Fri Aug 10, 2007 3:44 pm
    I have done it with Midi interfaces and Arkaos but after a few seconds the movies were out of sync even we were using the same computers with the same espects.
  • mowgli_uk
    by mowgli_uk » Mon Aug 13, 2007 11:44 am
    I've been working with this recently over a wireless network and it works a treat.
