Crash of Modul8 and Madmapper
  • videsad
    by videsad » Wed Sep 21, 2011 12:55 pm
    Hello
    last weekend i had a Show in our club, While the Show i had a hard Software Error. I use a a Macbook Pro 2.5Ghz intelcoreDuo. Mac OSX 10.6.8
    The Setup: Madmapper, Modul8, Mad_EQ, Mad_Doubler and Mad_Generator
    One Eiki 5000 Ansi VdeoProjektor
    In the beginning of the Party it was all ok.
    But after 3/4h the screen beginns to flicker wild and it was not possible to use any key or input with the Mouse.
    I dont know why this problem happend... :shock:
    After Hard boot and Restart of the Setup i had the same problem.
    Then i have restart my Mac and the Software. Put off the Wireless Connetin to the web and the i had no problems...
    No idea why this is so....
    Do you have any Idea?
    Greets from Bürgeln TG
    Videsad
    by franz » Wed Sep 21, 2011 4:01 pm
    Sounds like a GPU panic. Do you have an ATI X1600 ?
    Please go through our support and submit crash logs (whenever possible).
    by ilan » Wed Sep 21, 2011 4:48 pm
    We need Console logs as well. Open your Utilities folder, and launch the Console application. On the upper right field type in MadMapper and copy and paste the resulting text into your email to us. Do this with Modul8 as well.
  • videsad
    Use a Macbook Pro
    by videsad » Thu Sep 22, 2011 9:23 pm
    Hello franz.
    i have a MacbookPro wit a
    NVIDIA GeForce 8600M GT:
    Chipsatz-Modell: GeForce 8600M GT
    Typ: GPU
    Bus: PCIe
    PCIe-Lane-Breite: x16
    VRAM (gesamt): 512 MB
    I have sent the logs to ilan.
