paths
  • Buano
    paths
    by Buano » Mon Oct 31, 2005 5:24 pm
    hi there, I wanted to ask whether you guys have thought of adding paths (.ai files) into v2.5?
    i would personally love to see paths that are stroke and fillable. also the possibility of drawing paths and attaching stills or video clips to them. doing this would really open up the apps functionality and get away from the slighly clunky way the move function currently works
    keep up the good work :D
    yves@garagecube
    Re: paths
    by yves@garagecube » Mon Oct 31, 2005 9:56 pm
    Yes. It is interesting and may be implemented in Modul8 one day. The V2.5 will allow the creation of path (for motion) through the module system. Hopefully I'll have the time to write a module to edit path. Now you won't have support for new media types in the V2.5.
  • Guest
    by Guest » Tue Nov 01, 2005 1:02 pm
    thats wicked news Yves, cant wait to give it a try :o
